03-20-2018
06:11 AM
- Mute
- Permalink
- Report
03-20-2018
06:11 AM
Thanks, that works... i have a strange problem now tough...
i try to write some iproperties to my labels in the form.. this is the code:
Private Sub m_userinputevent_OnSelect(JustSelectedEntities As ObjectsEnumerator, ByRef MoreSelectedEntities As ObjectCollection, SelectionDevice As SelectionDeviceEnum, ModelPosition As Point, ViewPosition As Point2d, View As View) Handles m_userinputevent.OnSelect
If JustSelectedEntities.Count = 1 Then
oForm.Auswahl.Visible = True
For Each objEntity As Object In JustSelectedEntities
If TypeOf objEntity Is ComponentOccurrence Then
'Do whatever you need
Dim cmp As ComponentOccurrence = objEntity
oForm.AW_Bauteilnummer.Text = cmp.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
Try
oForm.AW_ERP_Nummer.Text = cmp.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("ERP_Nummer").Value
Catch
oForm.AW_ERP_Nummer.Text = ""
End Try
oForm.AW_Beschreibung.Text = cmp.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Description").Value
Try
oForm.AW_Nachbearbeitung.Text = cmp.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("tan_Nachbearbeitung").Value
Catch
oForm.AW_Nachbearbeitung.Text = ""
End Try
Try
oForm.AW_Biegeteil.Text = cmp.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("tan_Biegeteil").Value
Catch
oForm.AW_Biegeteil.Text = ""
End Try
Try
oForm.AW_Schweißbaugruppe.Text = cmp.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("wec_Schweißbaugruppe").Value
Catch
oForm.AW_Schweißbaugruppe.Text = ""
End Try
End If
Next
Else
oForm.Auswahl.Visible = False
End If
Try catch is used since older files dont have these custom properties.
The properties do exist in the file:
but if i click the IPT in my assembly only a few of the fields get filled in. why?
Moreover, if I edit the "biegeteil" value to "True", it still reads false, until i close and reopen the file.. no matter if I un select and reselect it.. is there a way to force it to re load the file with current data?
All i want to do is display those values of the selected file.
Thank you
