in reply to: MechMachineMan
I thought that would do it as well but I get this error
Error in rule: change, in document: Assembly1
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
I have put a message box to check/ debug that it is not the rest of the code. all that works fine up until the message box ( I have commented it out.
'define the assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'define the appearance library
Dim oLib As AssetLibrary
oLib = ThisApplication.AssetLibraries("Autodesk Appearance Library")
'make sure colors are in assembly doc
Dim libAsset As Asset
libAsset = oLib.AppearanceAssets.Item("Smooth - Red")
Try
	localAsset = libAsset.CopyTo(oAssyDoc)
Catch
'catch error if it's already local
End Try
libAsset = oLib.AppearanceAssets.Item("Smooth - Black")
Try
Catch
End Try
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oAsset As Asset
Dim oSS As SelectSet
oSS = oAssyDoc.SelectSet
Dim oSelCollection As New Collection
For Each oItem In oSS
	oSelCollection.Add(oItem)
Next
'set color overrides of components at the assembly level
For Each oOcc In oAsmCompDef.Occurrences.AllLeafOccurrences
	Dim MatchFound As Boolean = False
	For Each oItem In oSelCollection
		If oOcc.Equals(oItem) Then
			MatchFound = True
		End If
	Next
	' this works fine till this point' MessageBox.Show("Message", "Title")
	If MatchFound = True Then
		oAsset = oAssyDoc.Assets.Item("Smooth - Red")
	End If
	oOcc.Appearance = oAsset
Next
Kind Regards
