1020 Views, 1 Reply
03-12-2018
11:12 AM
- Mute
- Permalink
- Report
03-12-2018
11:12 AM
I am coding a rule that will export a flat surface of a part to DWG file. However I would like the rule to automatically show the front view (according to the viewcube) of the part prior to selecting the surface to export. What would be the code to do show front view (if any)?
03-12-2018
11:54 AM
- Mute
- Permalink
- Report
03-12-2018
11:54 AM
SyntaxEditor Code Snippet
ThisApplication.CommandManager.ControlDefinitions.Item("AppFrontViewCmd").Execute
Or there would be ways to do it without utilizing control definitions too, but that would take more coding.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
