MechMachineMan
1. Post your sample code.
2. Post links of things that might be similar to what you want if you don't know how to code
'define the assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'define the appearance library
Dim oLib As AssetLibrary
oLib = ThisApplication.AssetLibraries("Autodesk Appearance Library")
'make sure colors are in assembly doc
Dim libAsset As Asset
libAsset = oLib.AppearanceAssets.Item("Smooth - Red")
Try
	localAsset = libAsset.CopyTo(oAssyDoc)
Catch
'catch error if it's already local
End Try
libAsset = oLib.AppearanceAssets.Item("Smooth - Black")
Try
Catch
End Try
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oAsset As Asset
Dim oSS As SelectSet
oSS = oAssyDoc.SelectSet
Dim oSelCollection As New Collection
For Each oItem In oSS
	oSelCollection.Add(oItem)
Next
'set color overrides of components at the assembly level
For Each oOcc In oAsmCompDef.Occurrences.AllLeafOccurrences
	Dim MatchFound As Boolean = False
	For Each oItem In oSelCollection
		If oOcc.Equals(oItem) Then
			MatchFound = True
		End If
	Next
	If MatchFound = True Then
		oAsset = oAssyDoc.Assets.Item("Smooth - Red")
	Else
		oAsset = oAssyDoc.Assets.Item("Smooth - Black")
	End If
	oOcc.Appearance = oAsset
Next
 Edited by
Discussion_Admin
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
