1144 Views, 6 Replies
change sected parts colour in an assembley
hi all,
I am trying to put a bit of code together to over ride the appearance colour of parts in an assembly.
we are using cable tray and we change the colour of the tray in one view rep to show if it is for power or signal, we also want everyone who works on the project to do it the same way (this is where iLogic come in)
I want to put together a button (for example 24v needing to be red) so you select the parts ( that could be in the top level or in sub-assemblies) and then click the button and the rule changes the appearance colour to red.
I have looked all over and seam to find different codes but none does or can be easily changed to do what I need
any help would be great.
Thank you
