revans1234
in reply to: revans1234
So further to this, I tried the following lines to use extrusion-
Prof is the profile loop
PCD is the partcomponentdefinition
    Dim ExDef As ExtrudeDefinition
    Set ExDef = PCD.Features.ExtrudeFeatures.CreateExtrudeDefinition(Prof, kJoinOperation)
    Call ExDef.SetDistanceExtent(0.12, kNegativeExtentDirection) 'hardcoded thickness
    Call PCD.Features.ExtrudeFeatures.ADD(ExDef)
With this it is possible to force the extent direction.
And it now all works fine- the flat pattern is OK too.
So Kevin gets the solution- thanks very much for that.
Roger.
