268 Views, 1 Reply
Setting custom textstyle to active in custom Object Default
I am working with the Style and Standard Editor, and Library is currently set to Read/Write
  1. I have made a new Standard and it is set to active
  2. I have made a new Object Default standard, and it is set to active
  3. I have made a new textstyle, "Text A", it is local.
  4. I have set Object type> Title Block Text to Object Style, Text A
  5. Save and Close
When I open the text box in my drawing I can see text style has changed to Text A, but when I go back to the Editor and change fonts and color of Text A
Save, nothing happens to the textstyle in the textbox. Why?
Also, when in editor and filter is set to active, Text A disappear. So it obviously not active. How do I make it active?
chandra.shekar.g
Hello @Anonymous,
Can you please post the same question at Inventor Forum using below link?
https://forums.autodesk.com/t5/inventor-forum/bd-p/78
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
