@MechMachineMan wrote:
As an extra, to run VBA from iLogic, it looks something like this:
Dim invApp As Inventor.Application
invApp = ThisApplication
'To implement, you almost certainly need to change the indices (values in brackets) to match your code. invApp.VBAProjects(1).InventorVBAComponents("AppEventController").InventorVBAMembers("StartEvent").Execute
From iLogic you can also just use this line to call a VBA macro
	'call VBA Macro
    InventorVb.RunMacro("ApplicationProject", "Module1", "MyMacro")
I hope this helps.
Curtis
