MechMachineMan
in reply to: martinhoos
@martinhoos You cannot make the program jump between 2 rules concurrently.
Your best option here is to have the iLogic rule that I (and @chandra.shekar.g) posted run as your main vba rule, and embed the question within it, and then run the iLogic rule from it as needed.
If you have the question built into the external rule, just have the VBA fire the rule and DO NOT put the question in the VBA as it already exists in the rule.
If you would post more of your code, perhaps we could rewrite it or explain it better for you.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
