03-06-2018
12:42 AM
- Mute
- Permalink
- Report
03-06-2018
12:42 AM
Below VBA code is to get iLogic addin to run a rule by mentioning rule name.
Public Sub RuniLogic(ByVal RuleName As String)
Dim iLogicAuto As Object
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
If oDoc Is Nothing Then
MsgBox "Missing Inventor Document"
Exit Sub
End If
Set iLogicAuto = GetiLogicAddin(ThisApplication)
If (iLogicAuto Is Nothing) Then Exit Sub
iLogicAuto.RunExternalRule oDoc, RuleName
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
Dim addIns As ApplicationAddIns
Set addIns = oApplication.ApplicationAddIns
Dim addIn As ApplicationAddIn
Dim customAddIn As ApplicationAddIn
For Each addIn In addIns
If (addIn.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then
Set customAddIn = addIn
Exit For
End If
Next
Set GetiLogicAddin = customAddIn
End Function
Below code is to run rule by calling above function RuniLogic. If the answer is Yes from message box.
Sub Stl_Export_LN()
If MsgBox("Möchtest Du eine Plausibilitaetsprüfung?", vbYesNo + vbQuestion) = vbYes Then
RuniLogic ("Plausibilitaetsprüfung")
End If
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
