03-05-2018
08:30 PM
- Mute
- Permalink
- Report
03-05-2018
08:30 PM
That's nice information.
Try the below VBA code to run rule if the answer is yes.
Sub Stl_Export_LN()
If MsgBox("Möchtest Du eine Plausibilitaetsprüfung?", vbYesNo + vbQuestion) = vbYes Then
RuniLogic ("Plausibilitaetsprüfung")
End If
End Sub
Public Sub RuniLogic(ByVal RuleName As String)
Dim iLogicAuto As Object
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
If oDoc Is Nothing Then
MsgBox "Missing Inventor Document"
Exit Sub
End If
Set iLogicAuto = GetiLogicAddin(ThisApplication)
If (iLogicAuto Is Nothing) Then Exit Sub
iLogicAuto.RunExternalRule oDoc, RuleName
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
Dim addIns As ApplicationAddIns
Set addIns = oApplication.ApplicationAddIns
Dim addIn As ApplicationAddIn
Dim customAddIn As ApplicationAddIn
For Each addIn In addIns
If (addIn.ClassIdString = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}") Then
Set customAddIn = addIn
Exit For
End If
Next
Set GetiLogicAddin = customAddIn
End Function
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
