- Mute
- Permalink
- Report
iPart Dimension into iAssembly Table
I would like to get an iPart dimension (diameter) into my iAssembly table (even as a Reference or User Parameter are fine). Once I accomplish this I will be able to put the iAssembly on a drawing and make the "Diameter" Column update when I change the diameter in the original iPart.
The issue I've run into is whatever assembly is showing on my screen is saved as the permanent "Diameter" dimension, even when I switch to an assembly with a part of a different diamter.
In some situations there is no Helix 2 (look at DWG for details) and I would like the DIA to be shown as '--' (I imagine I can use iLogic ie: If Helix DIA > 20 then '--'. The request is that the Table updated automatically, when the either Disk DIA is changed, not manually typed in.
Thank you much for any help, guidance, or heading.
