MechMachineMan
in reply to: pball
@pball wrote:
You already mentioned the library file access issue, which has a work around but the work around is apparently buggy and allows changes to library files from the graphical interface and not just the API. There is supposed to be a fix so the work around only works with the API.
I also found something in the pdf export code that I've been using that is from the help samples or the forum. The following line throws an error and simply has to be removed as it's no longer needed or valid in 2018.
If PDFAddin.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
Other than that I've never had to make code changes from 2012 through 2018.
Oddly with this one, it looks like they changed the first argument from the oDataMedium just to the document (or maybe it's always worked), so if you replace oDataMedium with the DOCUMENT object, it appears to work in 2018. The library files is a good mention too. Big perk of 2018.2 and on is the addition of global event triggers which is very nice, imo.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
