@martinhoos,
Thanks for sample data.
With samples, understood the folder structures. Try the below modified iLogic code.
Sub Main()
	Dim oAsmDoc As AssemblyDocument
	oAsmDoc = ThisApplication.ActiveDocument
	oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) - 4)
	'check that the active document is an assembly file
	If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
	End If
	'get user input
	If MessageBox.Show ( _
	"This will create a PDF file for all of the asembly components that have drawings files." _
	& vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
	& vbLf & " " _
	& vbLf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _
	& vbLf & "This could take a while.", "iLogic - Batch Output PDFs ",MessageBoxButtons.YesNo) = vbNo Then
	Exit Sub
	End If
	Dim PDFAddIn As TranslatorAddIn
	Dim oContext As TranslationContext
	Dim oOptions As NameValueMap
	Dim oDataMedium As DataMedium
	Call ConfigurePDFAddinSettings(PDFAddIn, oContext, oOptions, oDataMedium)
	oPath = ThisDoc.Path
	oFolder = oPath & "\" & oAsmName & " PDF Files\"
	oPath = System.IO.Directory.GetParent(oPath).FullName
	If System.IO.Directory.Exists(oFolder) = False Then
		System.IO.Directory.CreateDirectory(oFolder)
	End If
	'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'look at the files referenced by the assembly
	Dim oRefDoc As Document
	Dim fileName As String
	' For Each oRefDoc In oRefDocs = oAsmDoc.AllReferencedDocuments
	For Each oRefDoc In oAsmDoc.AllReferencedDocuments
		oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) - 3)
		For Each fileName In System.IO.Directory.GetFiles(oPath, "*.idw",System.IO.SearchOption.AllDirectories)
			If fileName.EndsWith(oFileName + "idw") = True Then
				Dim oDrawDoc As DrawingDocument
				oDrawDoc = ThisApplication.Documents.Open(fileName, True)
				On Error Resume Next
				oDataMedium.FileName = oFolder & "\" & oFileName & "pdf"
				Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
				oDrawDoc.Close
				On Error GoTo 0
			End If
		Next
	Next
	'- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
	Dim oAsmDrawingName As String = ThisDoc.FileName(False) 'without extension
	For Each fileName In System.IO.Directory.GetFiles(oPath, "*.idw", System.IO.SearchOption.AllDirectories)
		If fileName.EndsWith(oAsmDrawingName + ".idw") = True Then
			Dim oAsmDrawingDoc As DrawingDocument
			oAsmDrawingDoc = ThisApplication.Documents.Open(fileName, True)
			oDataMedium.FileName = oFolder & oAsmDrawingName & ".pdf"
			Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
			oAsmDrawingDoc.Close
			On Error GoTo 0
		End If
	Next
	MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
	Shell("explorer.exe " & oFolder,vbNormalFocus)
End Sub
Sub ConfigurePDFAddinSettings(ByRef PDFAddIn As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
	PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oOptions.Value("All_Color_AS_Black") = 1
	oOptions.Value("Remove_Line_Weights") = 0
	oOptions.Value("Vector_Resolution") = 400
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	oOptions.Value("Custom_Begin_Sheet") = 1
	oOptions.Value("Custom_End_Sheet") = 1
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
