Not sure how I would be able to do that.
I would need sizes from schedule 10 up to 160 on pipe sizes from 1/2" to 24". Plus the information is set up in the content center for the part number, description, material, and special customer only information.. Another reason is that I use the change size feature while changing numerous custom parts that could be automated using iLogic, such as structural shapes, angle, flat bar, I-Beams etc. I prefer to drive my assemblies from a form that incorporates most of the needed information, and I simply place the parts/sub assemblies in the correct location.
I should point out I am hesitant to use the adaptive feature due to it not acting correctly by not updating, losing reference, and sometimes just freaking out. If I were to make the parts adaptive I would have to set that up on each assembly if I am correct. If I use my iLogic rules to do this I simply have to have the same name and parameters already set up in the parts that I use in my library. I can then place them in my assembly and they are ready to go.
