Brian.Price
3726 Views, 13 Replies
How can I use iLogic to change size of components?
I have an assembly with 3 parts, 2 of which are content center files that never change. The third file must be custom as it needs a different length every time. I can use iLogic to point to the 2 content center files and have them update according to the input. How can I then use iLogic to change the size of the third part according to the input and match the other 2 parts? The third part is set up in content center and is always saved as a custom part to be used in each unique assembly.
Normally I would go to each component and use the change size feature on each. When I get to the third I would also input the length I need.
I think being able to change size on each component would be easier too instead of using, if input = this then part = this.
Thanks.
