bradeneuropeArthur
in reply to: bshbsh
Normally spoken this will not be a huge problem because normally the API is added and not deleted.
But:
I was also having some problems in the past.
So for sure you will run into some bigger or smaller problems.
Remarks:
Take the step now to learn programming add ins.
This will have more benefits and can be defined on any version of inventor.
At least for some versions back because you are able to use older SDK's
regards
Arthur Knoors
Autodesk Affiliations:
