02-22-2018
04:49 AM
- Mute
- Permalink
- Report
02-22-2018
04:49 AM
Afterwards:
Public Sub UpdateRevisionTableStyle()
'check if the active document is a drawing document
If ThisApplication.ActiveDocumentType = kDrawingDocumentObject Then
Dim oIDW As DrawingDocument
Set oIDW = ThisApplication.ActiveDocument
Dim oIDWStyles As Inventor.DrawingStylesManager
Set oIDWStyles = oIDW.StylesManager
'Debug.Print oIDWStyles.DimensionStyle
MsgBox oIDWStyles.DimensionStyles.Item("BE_DIMENSION").LinearUnits
oIDWStyles.DimensionStyles.Item("YOUR DIM STYLE").LinearUnits = kInchLengthUnits
'YOUR CODE HERE
oIDWStyles.DimensionStyles.Item("YOUR DIM STYLE").LinearUnits= kMillimeterLengthUnits
Else
End If
End Sub
Arthur Knoors
Autodesk Affiliations:
