Yes I have:
Public Sub ChangeDimensionStyleUnit()
'check if the active document is a drawing document
 If ThisApplication.ActiveDocumentType = kDrawingDocumentObject Then
Dim oIDW As DrawingDocument
Set oIDW = ThisApplication.ActiveDocument
Dim oIDWStyles As Inventor.DrawingStylesManager
Set oIDWStyles = oIDW.StylesManager
'MsgBox oIDWStyles.RevisionTableStyles.Count
'Debug.Print oIDWStyles.DimensionStyle
MsgBox oIDWStyles.DimensionStyles.Item("YOUR DIM STYLE").LinearUnits
oIDWStyles.DimensionStyles.Item("BE_DIMENSION").LinearUnits = kInchLengthUnits
 Else
 End If
 End Sub
Arthur Knoors
Autodesk Affiliations:
