Hi @HermJan.Otterman
Thanks!
I tried this and failed. I'm close though!
For Each oRefDoc In oRefDocs
	'CHANGE INCHES TO MM FIRST - AFTER THAT, EXPORT
	dwgPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName)-3) & "dwg"
	'check to see that the model has a drawing of the same path and name
	If(System.IO.File.Exists(dwgPathName)) Then
				Dim oDrawDoc As DrawingDocument
				oDrawDoc = ThisApplication.Documents.Open(dwgPathName, True)
					Dim oStylesMgr As DrawingStylesManager = oDrawDoc.StylesManager
					MessageBox.Show(dwgPathName, "titel" )
					MessageBox.Show(oStylesMgr.ActiveStandardStyle.LinearUnits, "Title")
		                        MessageBox.Show(oStylesMgr.ActiveStandardStyle.InternalName, "titel" )
---> This is the wrong setting		oStylesMgr.ActiveStandardStyle.LinearUnits = UnitsTypeEnum.kMillimeterLengthUnits
					'MessageBox.Show(Kaas, "Title")
---> This is not allowed		oStylesMgr.DimensionStyles.Type = UnitsTypeEnum.kMillimeterLengthUnits
@Curtis_Waguespack Maybe you can figure out how with your magic?
___________________________
