02-20-2018
04:39 AM
- Mute
- Permalink
- Report
02-20-2018
04:39 AM
By default, Model tab is exported. If you want to export Structured tab, need to enable and export the same. Similarly for Parts Only tab. So, there are 3 xml files to export and import. Below VBA code exports different excels for different tabs.
Public Sub BOMExport()
' Set a reference to the assembly document.
' This assumes an assembly document is active.
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
' Set a reference to the BOM
Dim oBOM As BOM
Set oBOM = oDoc.ComponentDefinition.BOM
' Set the structured view to 'all levels'
oBOM.StructuredViewFirstLevelOnly = False
' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
' Set a reference to the "Structured" BOMView
Dim oStructuredBOMView As BOMView
Set oStructuredBOMView = oBOM.BOMViews.Item("Structured")
' Export the BOM view to an Excel file
oStructuredBOMView.Export "C:\temp\BOM-StructuredAllLevels.xls", kMicrosoftExcelFormat
' Make sure that the parts only view is enabled.
oBOM.PartsOnlyViewEnabled = True
' Set a reference to the "Parts Only" BOMView
Dim oPartsOnlyBOMView As BOMView
Set oPartsOnlyBOMView = oBOM.BOMViews.Item("Parts Only")
oPartsOnlyBOMView.Export "C:\temp\BOM-PartsOnly.xls", kMicrosoftExcelFormat
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
