02-19-2018
07:25 AM
- Mute
- Permalink
- Report
02-19-2018
07:25 AM
do I understand correctly:
you have a part that has as basis
you modify the part
you create assemblies etc
you need to have the basis of the part again
Then this option is maybe possible:
Save the file as a temporare file and restore it by coding.
otherwise you could try to read and write the bytes back to the part.
if you need help please let me know.
you modify the part
Arthur Knoors
Autodesk Affiliations:
