02-19-2018
04:05 AM
- Mute
- Permalink
- Report
02-19-2018
04:05 AM
I found where is the bug:
- From Inventor, the BOM has 3 tabs : Model, Structured and Parts only.
- When you export manually, all the 3 tabs are exported
- When you export by VBA, only the Model tab is exported, and it is only that tab which is restored, on Model, Structured and Parts only.
To check it :
1)VB export :
- From Inventor, on an assembly, edit the BOM to have different configs on the 3 tabs
- Using the macro, export the BOM config and stop the program
- Manually, from Inventor, load the exported config : you obtain same columns in all the 3 tabs
2)Manual export :
- Manually, export the BOM config to BOM_tempo.xml
- Manually, from Inventor, Edit and modify the BOM config
- Manually, import the BOM config from BOM_tempo.xml : you obtain the right config you saved
