02-16-2018
07:45 AM
- Mute
- Permalink
- Report
02-16-2018
07:45 AM
The exports worked just fine for me when I did a test run to get the desired results that you want (export with a new BOM Style, and revert the config back to the original).
This leaves me thinking you have 1 of 2 issues:
1. Your 'some code' is undoing part of the process or somehow causing issues.
2. Your code to overwrite the BOM_tempo is not working properly and instead of storing the BOM config from the current file, it's just using a config version that had been saved in the past, which is the config you are seeing it restored to (instead of it's original config).
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
