m.maertens6DTZT
868 Views, 4 Replies
update styles library
I'm Maarten and I'm trying to create a macro that allows me to update my entiry library from 2016 to 2018 automatically.
The library contains Parts, Iparts and iLogic components (assemblies).
So,
Let me first explain the steps that I need to follow when I must do this manually.
1. Open the iPart - masterfile on toplevel and modify the iproperties by adding a new Authority nr. (I need to modify this for our ERP system)
2. Update all styles ( Tab Manage)
3. Save
Then I insert this ipart into an assembly, update the style library and create all the variants according to the excell table.
I create all the parts by using following code:
And then all the parts are made.
But, I don't want to do this for all the iParts of my library.
What I want is to update styles, add authority nr, create all the variants in 1 action.
1. Insert ALL the iParts + parts in an assembly -
2. Press 1 button and the computer does the rest.
I created the following script, but I can't manage to update the COLOR styles of the part.
See below
Sub UpdateToNewRelease()
'Add a New Stock Number (switch to new structure in 2018)
' step 1 Declare stuff
    Dim oAssyDoc As AssemblyDocument
    Dim oComponent As ComponentOccurrence
    Dim oRefDoc As PartDocument
    Dim invCustomPropertySet As PropertySet
    Dim PropAuthority As Property
    Dim oPartDoc As PartDocument
    Dim oFactoryDoc
    Set oAssyDoc = ThisApplication.ActiveDocument
' step 2 - ask user for value of iproperty
    Dim AuthorityNr As String
    AuthorityNr = InputBox("What is the new Authority Number (Old Stock Number)", "Set Number", "")
' step 2 get a reference to each part
        For Each oComponent In oAssyDoc.ComponentDefinition.Occurrences
        If oComponent.IsiPartMember = False Then
            'change the part Authority number directly
          'set the Autority iProperty's
            Set oRefDoc = oComponent.ReferencedDocumentDescriptor.ReferencedDocument
            Set invCustomPropertySet = oRefDoc.PropertySets.Item("Design Tracking Properties")
            Set PropAuthority = invCustomPropertySet.Item("Authority")
            PropAuthority.Value = AuthorityNr
       Else
            'it is an ipart
            'open the ipart and change the numnber
                Set oPartDoc = oComponent.ReferencedDocumentDescriptor.ReferencedDocument
                Set oFactoryDoc = oPartDoc.ReferencedDocumentDescriptors.Item(1).ReferencedDocument
            'change the Autority Number of the factory document
                Set invCustomPropertySet = oFactoryDoc.PropertySets.Item("Design Tracking Properties")
PropAuthority.Value = AuthorityNr 'update styles Dim mat As Material For Each mat In oFactoryDoc.Materials If mat.UpToDate = False Then Call mat.UpdateFromGlobal Debug.Print mat.Name End If Next End If Next End Sub
When i open the ipart to verify - then I see that the authority nr is filled in, but the color is not updated automatically.
see below
Is there someone that can help me out how I can update the style libraries (type color) automatically??
That would be great!
Thanks a lot.
