I found the answer on my own.
I had to modify the custom parameter field in the iFactory each time I edited a child. Then, when I set the row of the child, it grabs that parameter. I was unable to specify parameter in the .ChangeRow call.
I think iFactories were intended to have only one row per child instance. This is not our setup. We have thickness and length in dropdowns/keys but the length is a custom parameter, is set to "1 in", and we do not have separate rows for separate lengths. Instead when you place the factory to create an instance/child, you type whatever you want into the custom parameter.
Technical notes:
You must close the excel table in order for the table to update
Editing the any of the key columns, even reformatting them, or even changing them and then changing them back, will break link to row.
Editing the custom parameter column will not break link.
Editing the iFactory in any way will make an update available to all children.
I have not attempted to edit the table inside Inventor (as opposed to excel)
This program runs best if no other excel processes are running (I've had OLE errors which are somehow not suppressed .DisplayAlerts)
Runtime is about 2 minutes per part with broken row and a couple seconds per part that just needs updating
Program seems stable running overnight.
Full code:
Option Explicit
Option Compare Text
Sub sciPartFolder()
    'debug
    Dim dTime As Double
    'settings
    Const sPath As String = "\\MKECOMP1\data\Eng Docs\Engineering Data\Core Kits, CNC Programs\_Closeout\"
    Const sFactory As String = "_MCI Closeout.ipt"
    Const sLogFilename As String = "FixLogCloseout.xlsx"
    'main objects
    Dim oFactory As iPartFactory
    Dim ohFactorySheet As WorkSheet
    Dim ocFactoryCells As Range
    Dim obFactoryBook As Workbook
    Dim asTable(30000, 5) As String 'empty, thk, wid, len, membername, pn#
    Dim R As Double
    Dim C As Integer
    Dim sFile As String
    Dim oDoc As Document
    Dim oIpart As iPartMember
    'parsing
    Dim sThk As String
    Dim sWid As String
    Dim sLen As String
    Const sDimFormat As String = "0.00"
    'logging
    Dim owLogBook As Workbook
    Dim ocLogCells As Range
    Dim L As Integer
    'fix reference
    Dim vComponentFolders As Variant
    Const sComponentFolders As String = "_Closeout,_Tooling Foam,_Closeout Structural,_Contour Balsa,_Balsa" 'lightweight is not handled
    Const sComponentFactories As String = "_MCI Closeout.ipt,_Tooling Foam.ipt,_Structural Closeout.ipt,_Contour Balsa.ipt,_Balsa.ipt"
    Dim vComponentFactories As Variant
    Dim sRemainder As String
    Dim sFilename As String
    Dim sFolderE1 As String 'folder above the filename
    Dim F As Integer
    Dim oDesc As DocumentDescriptor
Debug.Print "Starting at: " & Format(Now(), "hh:mm:ss")
    'Call fnPubRoutineEnter
    ThisApplication.SilentOperation = True
    ThisApplication.Documents.CloseAll
    'prep arrays
    vComponentFolders = Strings.Split(sComponentFolders, ",")
    vComponentFactories = Strings.Split(sComponentFactories, ",")
    'load oFactory table
    Set oDoc = ThisApplication.Documents.Open(sPath & sFactory, False)
    If oDoc.ComponentDefinition.IsiPartFactory = False Then Stop
    Set oFactory = oDoc.ComponentDefinition.iPartFactory
    Set ohFactorySheet = oFactory.ExcelWorkSheet
    Set ocFactoryCells = ohFactorySheet.Cells
    Set obFactoryBook = ohFactorySheet.Parent
Debug.Print "Opened worksheet: " & Format(Now(), "hh:mm:ss")
    For R = 1 To oFactory.TableRows.Count
        For C = 1 To oFactory.TableColumns.Count
            asTable(R, C) = Format(Replace(ocFactoryCells(R + 1, C), "in", ""), sDimFormat)
        Next C
    Next R
Debug.Print "Loaded worksheet: " & Format(Now(), "hh:mm:ss")
    'open log file
    Set owLogBook = Workbooks.Open("\\mkecomp1\data\SALES FOLDER\TRANSFER FILES\NJT-Sales Transfer\PROJECTS\Engineering\iParts\" & sLogFilename)
    Set ocLogCells = owLogBook.Sheets(1).Cells
    L = ocLogCells(dRowsMax, 1).End(xlUp).Row + 1
    'scroll in folder to next to do
    sFile = Dir(sPath & "*.ipt*")
    Debug.Print ocLogCells(L - 1, 1).Value
    Do Until sFile = ocLogCells(L - 1, 1).Value
        sFile = Dir
    Loop
    sFile = Dir
    'start processing fresh files
    Do Until sFile = ""
        Set oDoc = ThisApplication.Documents.Open(sPath & sFile, False)
        If oDoc.ComponentDefinition.IsiPartMember = False Then GoTo NextFile
        Set oIpart = oDoc.ComponentDefinition.iPartMember
        If oIpart.CustomMember = False Then GoTo NextFile
Debug.Print oIpart.Name
        'see if iPart needs attention. L think sometimes healthStatus might show ok when it isn't
        If oIpart.HealthStatus = kUpToDateHealth _
            Or oDoc.RequiresUpdate = False _
            Or oDoc.RecentChanges = 0 Then GoTo NextFile
        'fix broken links to factory
        If oDoc.ReferencedDocumentDescriptors(1).ReferenceMissing = True Then
            Set oDesc = oDoc.ReferencedDocumentDescriptors(1)
            'parse
            sRemainder = oDesc.FullDocumentName
            sFilename = Right(sRemainder, Len(sRemainder) - InStrRev(sRemainder, "\"))
            sRemainder = Left(sRemainder, InStrRev(sRemainder, "\") - 1)
            sFolderE1 = Right(sRemainder, Len(sRemainder) - InStrRev(sRemainder, "\"))
            If InStr(sComponentFolders, sFolderE1) = 0 Then Stop
            For F = LBound(vComponentFolders, 1) To UBound(vComponentFolders)
                If sFolderE1 = vComponentFolders(F) Then Exit For
            Next F
            sFilename = vComponentFactories(F)
            'fix it
            Call oDesc.ReferencedFileDescriptor.ReplaceReference( _
                "\\MKECOMP1\data\Eng Docs\Engineering Data\Core Kits, CNC Programs\" _
                & sFolderE1 & "\" & sFilename)
        End If
        'see if needs to reconnect to row
        On Error Resume Next
        R = -1
        R = oIpart.Row.Index 'if tables already loaded, this doesn't take time, even for parts which need updating (but are linked)
Debug.Print "   Got row: " & Format(Now(), "hh:mm:ss")
        On Error GoTo 0
        If R = -1 Then
            'data we might need / find row
            'dims via name, can also via oDoc.PropertySets(4)("Thickness")
            sThk = Left(oIpart.Name, 4)
            sWid = Mid(oIpart.Name, 6, InStrRev(oIpart.Name, "x") - 6)
            sLen = Mid(oIpart.Name, InStrRev(oIpart.Name, "x") + 1, Len(oIpart.Name) - 4 - InStrRev(oIpart.Name, "x"))
            'find row
                If asTable(R, 1) = sThk And asTable(R, 2) = sWid Then Exit For
            Next R
            If asTable(R, 1) <> sThk Or asTable(R, 2) <> sWid Then Stop
            'fix?
Debug.Print "   Opened worksheet: " & Format(Now(), "hh:mm:ss")
            ohFactorySheet.Cells(R + 1, 3).Value = sLen 'negligible time
Debug.Print "   Edited worksheet: " & Format(Now(), "hh:mm:ss")
            obFactoryBook.Save 'do we have to??, doesn't take very long
Debug.Print "   Saved worksheet: " & Format(Now(), "hh:mm:ss")
            excel.Application.DisplayAlerts = False
Debug.Print "turned off alerts...?"
            obFactoryBook.Close 'this has problems with balsa factory...
            Application.DisplayAlerts = True
            excel.Application.DisplayAlerts = True
Debug.Print "turned on alerts...?"
            'can we do something else?
Debug.Print "   Closed worksheet: " & Format(Now(), "hh:mm:ss")
            Call oIpart.ChangeRow(R) '~5 sec, potentially custom parameters in this???
Debug.Print "   Edited iPart: " & Format(Now(), "hh:mm:ss")
        End If
        'for anything that had fixes, need to update and save
        oDoc.Update 'this is what takes a long time
Debug.Print "   Updated doc: " & Format(Now(), "hh:mm:ss")
        oDoc.Save 'quite quick?
Debug.Print "   Saved doc: " & Format(Now(), "hh:mm:ss")
NextFile:
        'logging
        'Set owLogBook = Workbooks.Open("\\mkecomp1\data\SALES FOLDER\TRANSFER FILES\NJT-Sales Transfer\PROJECTS\Engineering\iParts\" & sLogFilename)
        'Set ocLogCells = owLogBook.Sheets(1).Cells
        ocLogCells(L, 1).Value = oDoc.DisplayName
        ocLogCells(L, 2).Value = Format(Now(), "hh:mm:ss")
        owLogBook.Save
        L = L + 1
        oDoc.Close
Debug.Print "   Closed doc: " & Format(Now(), "hh:mm:ss")
        DoEvents
        sFile = Dir
    Loop
    owLogBook.Close
    Call fnPubRoutineExit
End Sub
Sub sciPartSurvey()
    'nathan tonkinson 2/8/18
    'to see how many components need updating
    Dim sFile As String
    Dim oWb As Workbook
    Dim oCells As Range
    Dim I As Integer
    Set oWb = Workbooks.Open("C:\users\ntonkinson\desktop\testexcel.xlsx")
    Set oCells = oWb.Sheets(1).Cells
    I = 2
    'load/fix components
    Do Until sFile = ""
        oCells(I, 1).Value = oIpart.Name
        oCells(I, 2).Value = oIpart.HealthStatus
        oCells(I, 3).Value = oDoc.RequiresUpdate
        oCells(I, 4).Value = oDoc.RecentChanges
        I = I + 1
        Call oWb.Save
NextFile:
        oDoc.Close
        DoEvents
        sFile = Dir
    Loop
    Call oWb.Save
    Call oWb.Close
End Sub
