'Define file name to export current BOM config
BOM_tempo = "c:\temp\custom BOM.xml"
'if existing file, delete it
On Error Resume Next
Kill BOM_tempo
On Error GoTo 0
'Export active BOM config, in order to restore it
Call oBOM.ExportBOMCustomization(BOM_tempo)
'Load the custom BOM config file
oBOM.ImportBOMCustomization ("c:\temp\custom BOM.xml")
Arthur Knoors
Autodesk Affiliations:
