Sort of fixed the problem, but created a new one. I added an exception to skip the offending ipt. Doing so still allows everything to update as it should from the master sketch, BUT, it won't iterate all the way through the ReplaceComponents sub. I am thinking it wants to see that other file, but since it's not there it errors out. I have tried to add an exception there as well to skip the recursive call on that specific assembly but no joy.
Any input would help at this point (as will going home and forgetting about all this for a little while!)
Public newPath As String
Public FilePath As String
Public newFolPath As String
Public file_name As String
Public Sub PlaceCompartment()
    'get the object from the active document
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    'on run, display the different options with a GUI and buttons - also sets the filepath to the desired assembly file
    AsmForm.Show
    'get new path
    Call GetPath
    'perform save as of needed assembly and parts
    Call SaveNew(FilePath)
    'ComponentReplace(
End Sub
Public Function GetPath() As String
    'set up the dialog
    Dim fileDlg As FileDialog
    'create file dialog object
    Call ThisApplication.CreateFileDialog(fileDlg)
    'define filter
    fileDlg.Filter = "Assembly File (*.iam)|*.iam"
    'define the part and assembly files filter to be the default filter
    fileDlg.FilterIndex = 1
    'file dialog title
    fileDlg.DialogTitle = "Save File As"
    'throw error when user hits cancel
    fileDlg.CancelError = True
    'show file dialog
    On Error Resume Next
    fileDlg.ShowSave
    newPath = fileDlg.Filename
    Call GetFolderPath(newPath)
End Function
' Return the path of the input filename.
Public Function GetFolderPath(fPath) As String
    ' Extract the path by getting everything up to and
    ' including the last backslash "\".
    newFolPath = Left$(fPath, InStrRev(fPath, "\"))
End Function
Sub SaveNew(fPath)
    'declare the new assembly
    Dim newAsm As AssemblyDocument
    Set newAsm = ThisApplication.Documents.Open(fPath, False)
    'save as on the new assembly
    Call newAsm.SaveAs(newPath, False)
    'close the file
    newAsm.Close
    'open the newly created assembly
    Dim asmCopy As AssemblyDocument
    Set asmCopy = ThisApplication.Documents.Open(newPath, False)
    'save as for all the components in the active assembly
    Call CopyOccs(asmCopy)
    'replace existing components with newly created components in assembly's folder
    Call ReplaceOccs(asmCopy.ComponentDefinition.Occurrences)
    'save the changes!
    asmCopy.Save
    'close the document!
    asmCopy.Close
End Sub
Private Sub CopyOccs(asmDoc As AssemblyDocument) 'the sub locates all referenced files and copies them to the new directory
    'declare enumerator and assign the docs from the passed (opened) file
    Dim refDocs As DocumentsEnumerator
    Set refDocs = asmDoc.AllReferencedDocuments
    'set count variable for iteration = the number of reference docs
    Dim compCount As Integer
    compCount = refDocs.Count
    Dim refdoc As Document
    'Dim progressBar As Inventor.progressBar
    'Set progressBar = ThisApplication.CreateProgressBar(False, compCount, "Copying Assembly...", True)
    'Dim amount As Integer
    'amount = 100 / compCount
    'iterate through the reference documents
    For j = 1 To compCount
        Set refdoc = refDocs.Item(j)
        If refdoc.FullFileName = "C:\Users\Michael Peterson\CAD Support Files\Compartments\Single Door\Single Door FG Files\Single Door FG Frame.ipt" Then
            j = j + 1
        Else
            'get the active document's full file name to strip all preceding the name
            Dim newDocName As String
            newDocName = refdoc.FullFileName
            'call the function to strip out the name
            Call FNameOnly(newDocName)
            'concatenate the new folder path with the active file name
            Dim newDocPath As String
            newDocPath = newFolPath & file_name
            Call refdoc.SaveAs(newDocPath, False)
            'Set progressBar.Message
            'progressBar.UpdateProgress
            End If
            Next
    'progressBar.Close
End Sub
Private Sub ReplaceOccs(asmOccs As ComponentOccurrences)
    'error for if the active doc is not an assembly
    If asmOccs.Count = 0 Then
        MsgBox ("Assembly does not include any occurrences")
        Exit Sub
    End If
    'get the number of iterations needed
    compCount = asmOccs.Count
    'iterate through the occurrences
    For i = 1 To compCount
        'set the current occurrence
        Dim compOcc As ComponentOccurrence
        Set compOcc = asmOccs(i)
        'get occurrence's path
        Dim filen As String
        filen = compOcc.Definition.Document.FullFileName
        'strip out all but the name
        Call FNameOnly(filen)
        'concatenate with newFolPath
        Dim compPath As String
        compPath = newFolPath & file_name
        'replace the current occurrence with the new one
        Call compOcc.Replace(compPath, False)
        'recursively call the function if a subassembly
        If compOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
'CHECK HERE IN MORNING IF THERE IS STILL A PROBLEM
            If filen = "C:\Users\Michael Peterson\CAD Support Files\Compartments\Single Door\Single Door FG Files\Single Door FG Frame.iam" Then
                i = i + 1
            Else
                Call ReplaceOccs(compOcc.SubOccurrences)
            End If
        End If
    Next
End Sub
' Return the name of the file, without the path.
Public Function FNameOnly(ByVal fName As String) As String
    ' Extract the filename by getting everything to
    ' the right of the last backslash.
    file_name = Right$(fName, Len(fName) - InStrRev(fName, "\"))
End Function
Public Sub ReplaceComponents()
End Sub
