S_Verbeek
265 Views, 1 Reply
Run a external rule when a user parameter is changed?
is ther a way to run a external rule when a user parameter is changed?
In the event trigger it is only possible with model parameter but not with user parameters.
Best regards
Stefan
__________________________________________________________________________________
Stefan Verbeek
Mitarbeiter Support bei
Arthur Knoors
Autodesk Affiliations:
