- Mute
- Permalink
- Report
@Anonymous
There is one more checking required to perform iPartMember.ChangeRow() method. That is whether iPartMember is Custom member or not. This can be verified by iPartMember.CustomMember Property. This returns true if the iPartMember is a Custom member. The modified VBA code looks like below.
Sub Test_iPartFolder()
Dim sFile As String
Const sPath As String = "C:\users\ntonkinson\desktop\102767\"
Dim oDoc As Document
Dim oIpart As iPartMember
sFile = Dir(sPath & "*.ipt*")
Do Until sFile = ""
Set oDoc = ThisApplication.Documents.Open(sPath & sFile, False)
If oDoc.ComponentDefinition.IsiPartMember = False Then GoTo NextFile
Set oIpart = oDoc.ComponentDefinition.iPartMember
If oIpart.HealthStatus <> kUpToDateHealth Then GoTo NextFile
If oIpart.CustomMember = False Then GoTo NextFile
Dim iPart As PartDocument
Set iPart = oIpart.ReferencedDocumentDescriptor.ReferencedDocument
Dim oDef As PartComponentDefinition
Set oDef = iPart.ComponentDefinition
Dim iFactory As iPartFactory
Set iFactory = oDef.iPartFactory
Dim oRow As iPartTableRow
Set oRow = iFactory.TableRows.Item(4)
Call oIpart.ChangeRow(oRow) 'works if I only call an int, but not if I use other arguments
'in this specific test case, I know I need to call row 668. Later I will add logic to determine what row is needed.
oDoc.Update
oDoc.Save
NextFile:
oDoc.Close
DoEvents
sFile = Dir
Loop
End Sub
In your case, "Length" is a custom parameter column as shown below.
Desire iPartTableRow can be searched through TableRows of iPartFactory by comparing the "Length" parameter. iPartTableRow is also a Input parameter for iPartMember.ChangeRow() method.
Can you please provide sample iPart and iPartMember files to select desire iPartTableRow? Please make sure that files are non confidential.
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
