- Mute
- Permalink
- Report
If I've understood the Name of a material asses is the fixed international name of that material, and the DisplayName of the asset changes with the language used.
For example in my program I can see that an Inventor part has a Name of "Metal-022" and a DisplayName of "Copper - Satin".
Is there a table or method of getting all the Names and their corresponding DisplatNames in the various languages?
- Mute
- Permalink
- Report
What version of inventor?
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
You may want to check these files:
C:\Users\Public\Documents\Autodesk\Inventor 2018\Design Data\materialmapping.xml
C:\Users\Public\Documents\Autodesk\Inventor 2018\Design Data\proteinmapping.xml
C:\Users\Public\Documents\Autodesk\Inventor 2018\Design Data\externalmaterialmapping.xml
or these files:
C:\Users\Public\Documents\Autodesk\Inventor 2018\Design Data\Materials\InventorMaterialLibrary-xxx.xlf
