You need to change this is your "DESIGNATION" properties:
DESIGNATION PROPERTIESDESIGNATION PROPERTIES
This should solve it.
WHY IS THAT:
Because the information is only read from the family so is actually fix.
But you use the inventor features like "Frame gen." or "tube and Pipe", so the values are never selected from the selection table.
This is why the {P_L} is not working and the = ##### <P_L> is working.
if you need more assistant please let me know.
Arthur Knoors
Autodesk Affiliations:
