- Mute
- Permalink
- Report
Yes i have tried that before but its not exactly the best method.
for one, i cant access the prompted entries by code and another is i still cant access the choice of sheets.
'YOU CAN ACCES THAT AFTERWARDS VIA CODING
but yes, your suggested version will simply add a sheet based on the currently active sheet.
Is there not a method of just selecting the sheet number and adding a new version of it?
Arthur Knoors
Autodesk Affiliations:
