bradeneuropeArthur
Please try to formulate your problem again.
  • What was the situation before the upgrade.
  • From what version did you upgrade.
  • To what version did you upgrade.
  • What went wrong.
regards,
Arthur Knoors
Autodesk Affiliations:
