This code adds the sheet in the current format:
Public Sub AddSheet()
Dim oCDef As ControlDefinition
Set oCDef = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingNewSheetCtxCmd")
oCDef.Execute
End Sub
Arthur Knoors
Autodesk Affiliations:
