This Code is working, but need to investigate the titleblock add function.
This seems to be a bug in inventor.
        Dim a As Inventor.Application
        a = _InvApp
        Dim b As DrawingDocument
        b = a.ActiveDocument
        Dim sh As Sheet
        sh = b.ActiveSheet
        Dim shts As Sheets
        shts = b.Sheets
        Dim newsh As Sheet
        newsh = shts.Add
        Dim bo As BorderDefinition
        bo = b.BorderDefinitions.Item(2)' REPLACE WITH THE NAME OF THE BORDER YOU NEED
        Dim He As TitleBlockDefinition
        He = b.TitleBlockDefinitions.Item(1)' REPLACE WITH THE NAME OF THE TITLEBLOC YOU NEED
        newsh.Activate()
        Call newsh.AddBorder(bo)
        newsh.Activate()
        Dim titlebl As Inventor.TitleBlock
        titlebl = newsh.AddTitleBlock(He)
    End Sub
Arthur Knoors
Autodesk Affiliations:
