- Mute
- Permalink
- Report
Drawing Sheet - BaseView Creation VB
Hi
Im sure i had this working before but i seem to have forgotten.....
Using code, i am adding a drawing sheet to a drawing then adding a baseview. I cant use a SheetFormat because we dont work that way. Instead, we just use the built in Create Sheet button method. This will create a new sheet based on the currently active sheet.
How can i do this in code?
Basically, our template has 3 standard sheets
- Front
- Assy
- Part
I need to be able to create a sheet using the built in sheets based on the type. I have the type code, i just cannot get the correct drawing sheet. currently, its just a blank sheet with no border or titleblock...
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
