I found what the issue is:
  • In the parameter table there is no key defined for the PL value.
  • The parameter L was mapped. make that value empty.
  • Delete all your written text for the file name (Blue) text to black text. this means that the expression is calculated and not the written text.
I can upload the changed library if you want but it has been migrated to 2018 inventor.
please let me know.
Arthur Knoors
Autodesk Affiliations:
