- Mute
- Permalink
- Report
you need to create the directory step by step (Per directory) when not existing yet.
for example:
you nee directory which is not existing:
like:
C\Test\Directory1\Directory2
then you need to do it like
on error resume next
Mkdir "C\Test"
Mdir "C\Test\Directory1"
Mdir "C\Test\Directory1\Directory2"
Arthur Knoors
Autodesk Affiliations:
