- Mute
- Permalink
- Report
last option could be:
this allows you to edit the Content Center part;
ThisApplication._LibraryDocumentModifiable = True
Don't forget to set it back to false for the Application
with:
ThisApplication._LibraryDocumentModifiable = false
Completed Code:
Dim fileName As String
Dim path As String
path = ThisDoc.WorkspacePath()
fileName = "filename"
ThisDoc.Document.SaveAs(path & "\" & "900C7H" & L_1 & ".ipt" , False)
doc = ThisDoc.Document
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
iLogicVb.UpdateWhenDone = True
MessageBox.Show("Your file has been made", "SPACER")
Arthur Knoors
Autodesk Affiliations:
