- Mute
- Permalink
- Report
Code not working in 2018 but works in 2012
I have looked this over and I can't figure out why it is giving me this error.
1st time I even seen this kind of error on ilogic.
I supplied the part I will warn you don't hit continue it will stick you in a loop and you will have to force close Inventor.
Now this is in a library folder it works if the part is in the project workspace but I can't have that they need to be in a library so they cannot modify the part by accident .
It works fine in 2012 as a library but not in 2018.
Thanks for the help.
- Mute
- Permalink
- Report
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
I have opened the part and made a couple of edits using 2018 and have no issues or errors.
- Mute
- Permalink
- Report
Dim fileName As String
Dim path As String
path = ThisDoc.WorkspacePath()
fileName = "filename"
ThisDoc.Document.SaveAs(path & "\" & "900C7H" & L_1 & ".ipt" , False)
doc = ThisDoc.Document
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
iLogicVb.UpdateWhenDone = True
MessageBox.Show("Your file has been made", "SPACER")
- Mute
- Permalink
- Report
Did you put it in a library and mapped in projects?
It works if it is in the project folder but not in library..
- Mute
- Permalink
- Report
Since you said this is in a library folder, it could be related to the "bug fix" in 2018 which removes the ability for the API to modify library parts. In the past the API could edit parts in library folders that could not be edited manually. That issue is discussed along with a hidden bypass for the fix added in 2018.2 in the thread below.
https://forums.autodesk.com/t5/inventor-customization/ilogic-error/td-p/7133836
- Mute
- Permalink
- Report
What went wrong?
Arthur Knoors
- Mute
- Permalink
- Report
If you are talking about the update I guess I had to load 2018.2 before I load 2018.2.1
But neither of the updates fixed my issue..
- Mute
- Permalink
- Report
In VBA, you now have to use:
ThisApplication.[_LibraryDocumentModifiable] = True
That also works in iLogic.
-Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
- Mute
- Permalink
- Report
Put this line in it's own rule, run it, then try your code again:
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
No luck...
Put it in his own did not work and would not let me exit so I had to task manager close Inventor..
- Mute
- Permalink
- Report
Did you try
makedirectory for each directory
like:
on error resume next
Mkdir "C\Test"
Mdir "C\Test\Directory1"
Mdir "C\Test\Directory1\Directory2"
Arthur Knoors
- Mute
- Permalink
- Report
last option could be:
this allows you to edit the Content Center part;
ThisApplication._LibraryDocumentModifiable = True
Don't forget to set it back to false for the Application
with:
ThisApplication._LibraryDocumentModifiable = false
Completed Code:
Dim path As String
Arthur Knoors
- Mute
- Permalink
- Report
Not sure what you mean by make directory for each directory..
I need it to go into the project path..
- Mute
- Permalink
- Report
you need to create the directory step by step (Per directory) when not existing yet.
for example:
you nee directory which is not existing:
like:
then you need to do it like
Mkdir "C\Test"
Arthur Knoors
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Don't forget to set the value to False again!!!
To prevent you from problems as written in my post.
Good to here that it has been solved.
Arthur Knoors
