insomnix
I was running into the same problem. Found this post in the search to resolve my issue and thought I would come back with the solution I found through some trial and error.
In the code below I am iterating through sub assemblies to set the color of parts and it is designed to drill down into the sub assembly. I was trying to use "Component.Color" to change the color of sub parts and ran into a similar problem. Strangely, the part would have the new color associated with it when I examine the part, but it would not update the color on the screen.
When I changed the code to use "SetRenderStyle" the color would update correctly. Hope this helps the next person that comes along with this issue.
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
' set color for the standard screws
Call SetColor(asmDoc.ComponentDefinition.Occurrences,"R14400","Zinc")SyntaxEditor Code Snippet
Private Sub SetColor(Occurrences As ComponentOccurrences, SearchName As String, Color As String)
    ' Iterate through each of the occurrences in the collection provided.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    Dim occ As ComponentOccurrence
    For Each occ In Occurrences
        ' Check to see if the object is active.
        If Component.IsActive(occ.Name) = True Then
        ' Check to see if the part number from the iProperties matches the search name.
            If iProperties.Value(occ.Name, "Project", "Part Number") = SearchName Then
                ' Set the part color
                'Component.Color(occ.Name) = Color
                Call occ.SetRenderStyle(kOverrideRenderStyle,oAsmDoc.RenderStyles.Item(Color))
            End If
            If occ.DefinitionDocumentType = kAssemblyDocumentObject Then
                    Call SetColor(occ.SubOccurrences, SearchName, Color)
                End If
            End If
        End If
    Next
End Sub
