- Mute
- Permalink
- Report
Excel find Column
i try to find a column with iLogic. I got two Headlines in the first row of my Excel. "Type 1" and "Type 2". Also a Parameter in Inventor "Type" which has the Inputs "Type 1" and "Type 2"
The Headlines are in Column A and B. It the Parameter in Inventor is "Type 2" so my result should be coulum "B".
Is there a way to do that?
Kind regards
- Mute
- Permalink
- Report
Embed the excel list or link it to the inventor part or assembly.
The parameters in excel are now visible inventor
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
Thanks for your answer. Unfortunately i need to do it with iLogic because i cant embed the Excel Sheet in my case.
