712 Views, 2 Replies
Object Reference Not Set Error - When Running iLogic Code
I have an iLogic rule which works fine on my PC, but whenever i jump onto a different code and try to run the code i get the message:
Error in code:....
Object Reference not set to an instance of an object
What are common issues that cause this, can someone list them?
bradeneuropeArthur
Can you upload the code as text?
Arthur Knoors
Autodesk Affiliations:
