- Mute
- Permalink
- Report
Right Click Menu
Hi
Is it possible to add a custom menu line on the Right Click menu of a drawing view? I would like to add a button where the red line currently is (or somewhere in that region)
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
- Mute
- Permalink
- Report
with this piece of code:
Public Sub AddButtonToRightMouseButton(oButton As Inventor.ButtonDefinition, oCommandBar As Inventor.CommandBar)
Try
'MsgBox(oCommandBar.Controls.Item(1).DisplayName)
' Check if the context menu has the 'Home View' (formerly 'Isometric View') command
Dim oCmdBarControl As CommandBarControl
oCmdBarControl = oCommandBar.Controls.Item("AppIsometricViewCmd")
Dim ControlsCounter As Integer
ControlsCounter = oCommandBar.Controls.Count
If Not oCmdBarControl Is Nothing Then
' Add the button command before the home view command
'Call CommandBar.Controls.AddButton(m_largeButtonDataCard, oCmdBarControl.Index)
' add the buttonCommand to the end
Call oCommandBar.Controls.AddButton(oButton, ControlsCounter)
End If
Catch ex As Exception
End Try
End SubTo provide you the complete add in I need some more time.
- Regarding the Buttons
- and the commandbars
let me know if this is sufficient for the moment?
Arthur Knoors
Autodesk Affiliations:
