- Mute
- Permalink
- Report
Is Possible:
Check this:
Dim oTransMgr As TransactionManager
Dim m_inventorApplication as inventor.application
m_inventorApplication = thisapplication
oTransMgr = m_inventorApplication.TransactionManager Dim oTrans As Transaction oTrans = oTransMgr.StartTransactionForDocumentOpen("DEscription Of the Command") 'YOUR CODE HERE 'YOUR CODE HERE oTrans.End()
The rule or command can now simply being undo with the undo button in Inventor or Ctrl+Z
Arthur Knoors
Autodesk Affiliations:
