- Mute
- Permalink
- Report
as i replied.
the item from the API is always the latest.
Also after renumbering the item of the API stays the latest Number.
The ItemNumber of the Bom is only a nickname
If you have ie:
API Item _________Bom ItemNumber
1 2
2 3
3 4
and you add one
4 5
and you renumber this
1 2
2 3
3 4
4 1
the API item keeps 4
Arthur Knoors
Autodesk Affiliations:
