Put this to your code:
' i is needed for the rows to be sorted. Maximum items of the BOM
Public Sub ExcelSortColumns(a As Workbook, i As Integer)
Dim b As Worksheet = a.Worksheets("SHEETNAME")
Dim r As Range = b.Range("A1:G" & i)
r.Sort(r.Columns(1), XlSortOrder.xlAscending, , , , , , XlYesNoGuess.xlYes, , , XlSortOrientation.xlSortColumns, XlSortMethod.xlPinYin, )
End Sub
Arthur Knoors
Autodesk Affiliations:
