idealogicERZYZ
3724 Views, 25 Replies
ilogic export BOM
I'm using the following rule:
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Strukturalny")
xlApp = CreateObject("Excel.Application")
'comment out or change to false
'in order to not show Excel
xlApp.Visible = True
xlWorkbook = xlApp.Workbooks.Open("C:\Temp\Szablon.xlsx")
xlWorksheet = xlWorkbook.Worksheets.Item("BOM")
Dim row As Integer
row = 3
'xlWorksheet.Range("B4").Value = "ITEM"
'xlWorksheet.Range("C4").Value = "QTY"
'xlWorksheet.Range("D4").Value = "DESC"
'xlWorksheet.Range("E4").Value = "Part Number"
'Dim bRow As bomRow
bRows = oBOMView.BOMRows
For Each bRow In bRows
Dim rDoc As Document
rDoc = bRow.ComponentDefinitions.Item(1).Document
Dim docPropertySet As PropertySet
docPropertySet = rDoc.PropertySets.Item("Design Tracking Properties")
xlWorksheet.Range("A" & row).Value = bRow.ItemNumber
xlWorksheet.Range("B" & row).Value = docPropertySet.Item("Part Number").Value
xlWorksheet.Range("C" & row).Value = bRow.ItemQuantity
xlWorksheet.Range("D" & row).Value = docPropertySet.Item("Stock number").Value
xlWorksheet.Range("E" & row).Value = docPropertySet.Item("Vendor").Value
xlWorksheet.Range("F" & row).Value = docPropertySet.Item("Description").Value
xlWorksheet.Range("G" & row).Value = docPropertySet.Item("Cost").Value
row = row + 1
Next
oNow = DateString & "_" & TimeString
oNow = oNow.Replace("/","_")
oNow = oNow.Replace(":","_")
xlWorkBook.SaveAs(Filename:="C:\Temp\BOM-" & oNow & ".xlsx")
xlWorkbook.Close (True)
xlApp.Quit
The problem is that using this rule after export the new element adds to my list at the end of my xls template.
If I use the export icon from .iam - then structural BOM exports correctly:
And I get the correct xls:
Any idea why this is happening ...
Ed
Because it is the latest item added.
I you look how inventor exports the Bom this is different because they do not use the Item Number.
Solution:
Sort your Excel file afterwards via coding
Arthur Knoors
Autodesk Affiliations:
I believe my signature has a nice example listed of how to sort the BOM after export to excel.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Justin,
But what solution ? Where is it ?
Please enter the link
Ed
Put this to your code:
' i is needed for the rows to be sorted. Maximum items of the BOM
Public Sub ExcelSortColumns(a As Workbook, i As Integer)
Dim b As Worksheet = a.Worksheets("SHEETNAME")
Dim r As Range = b.Range("A1:G" & i)
r.Sort(r.Columns(1), XlSortOrder.xlAscending, , , , , , XlYesNoGuess.xlYes, , , XlSortOrientation.xlSortColumns, XlSortMethod.xlPinYin, )
End Sub
Arthur Knoors
After exporting it is an easy matter - but why it does not export by the rule.
Ed
as i replied.
the item from the API is always the latest.
Also after renumbering the item of the API stays the latest Number.
The ItemNumber of the Bom is only a nickname
If you have ie:
API Item _________Bom ItemNumber
1                             2
2                             3
3                             4
and you add one
4                             5
and you renumber this
1                             2
2                             3
3                             4
4                             1
the API item keeps 4
Arthur Knoors
Something does not work after my pasting.
Can you send the whole with my script?
Ed
Dim oBOM As BOM
Dim row As Integer
row = 3
'Dim bRow As bomRow
row = row + 1
Next
Dim r As Range
' How many Colums defined by G how many rows defined by i
r= xlWorksheet.Range("A1:G" & i)
'IE
'r= xlWorksheet.Range("A1:G100") r.Sort(r.Columns(1), XlSortOrder.xlAscending, , , , , , XlYesNoGuess.xlYes, , , XlSortOrientation.xlSortColumns, XlSortMethod.xlPinYin, ) oNow = DateString & "_" & TimeString oNow = oNow.Replace("/","_") oNow = oNow.Replace(":","_") xlWorkBook.SaveAs(Filename:="C:\Temp\BOM-" & oNow & ".xlsx") xlWorkbook.Close (True) xlApp.Quit
Arthur Knoors
Type: Range is not defined
An element was not declared: XISortOrder. It may be unavailable from the level of its protection.
did you add a reference to Excel.
This is missing I think!
Arthur Knoors
I do not know how
I can send you everything, but be carefull with using copied code from external without knowing how it works and how to modify it in future.
I little training in I logic or better in a programming language would be very useful and critical for you I think.
Please let me know how we can help you to a higher level regarding programming!?
Arthur Knoors
For now, this code is enough for me. If you can, send me the whole.
I will be grateful. Thank you.
Ed
What version of excel are you using.
Need this for the reference path
Arthur Knoors
MS Office 2016. Should I submit my template?
Ed
Hello
Can I ask for everything, along with the code.
greetings
Ed
Of course
Arthur Knoors
Please send me a private message so I will not forget.
I am not at my desk right now.
Arthur Knoors
idealogic@onet.pl
thank you in advance
greetings
Ed
