GosponZ
557 Views, 7 Replies
dwf file
On some our files DWF files are not published very well. Lines are missing. Does anybody has same problem or how to solve this?
 Autodesk?
chandra.shekar.g
in reply to: GosponZ
Hi @GosponZ,
Can you please provide sample drawing to publish dwf file?
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
GosponZ
in reply to: chandra.shekar.g
Sorry took me so long. No I can't post any file but very interesting is that is not all the time. Most of files are just Good but some just mess like that one above. I was thinking if there is any kind set up for dwf file so they can be good all the time.
Thank you
Are these inventor dwg files?
Are you publishing form Vault?
Arthur Knoors
Autodesk Affiliations:
Yes Inventor dwg and published on check in
Check your DwgTrueviewSettings for vault.
C:\Program Files\Autodesk\Vault ?????\Explorer\TrueViewSetup.dwg
Arthur Knoors
I Changed to 0 layer. Looks good. I do not know if that fixed problem because as I said not on all files happened. But anyway thank you for your help.
Good to hear that it is solved for now.
Thanks are appreciated.
Arthur Knoors
